11/18/14 Steaming up a locomotive/Likely 489
Unread postby Larry Sullivan » Tue Nov 18, 2014 6:45 am
Dark puff just came up over the engine house, seems to be building a bit -- likely steaming up 489?
bandicam 2014-11-18 08-42-48-914.jpg (116.73 KiB) Viewed 6285 times
Last edited by Larry Sullivan on Tue Nov 18, 2014 7:14 am, edited 1 time in total.
Re: 11/18/14 Steaming up a locomotive?
Unread postby Sharon Evans » Tue Nov 18, 2014 6:48 am
Also some coaches have been shifted over in front of the station building.
Unread postby Larry Sullivan » Tue Nov 18, 2014 6:49 am
Sharon Evans wrote:Also some coaches have been shifted over in front of the station building.
Those were put there yesterday Sharon, if you look over on Larry G's thread he covered pretty good what happened yesterday. #15 did the work of the day. My guess is more shifting around today, get the train fully ready to go and heads out tomorrow -- that's pure guesswork though.
Unread postby Larry Gibson » Tue Nov 18, 2014 7:11 am
Good sign is no additional snow over night as the area where the pipe flats and gons were moved from is still snow free.
Perhaps a train today.
Re: 11/18/14 Steaming up a locomotive/Likely 489
Unread postby Frank Criswell » Tue Nov 18, 2014 7:45 am
I have heard the term Hospital Train used a few times.
What is that?
Thanks,
Frank
Frank Criswell
Unread postby jonathan c45 » Tue Nov 18, 2014 7:49 am
Frank Criswell wrote:I have heard the term Hospital Train used a few times.
What is that?
Thanks,
Frank
its means the train is going to get some work on
jonathan c45
Unread postby Tom Casper » Tue Nov 18, 2014 7:58 am
Frank,
Antonito does car repair and any cars that need work or inspection will need to spend the winter over there. So all is gathered up in Chama and lugged over there. It got nicked named the Hospital train as that is usually a train that has cars that need work on them
Unread postby Jim Reynolds » Tue Nov 18, 2014 9:36 am
I have lost track of where all the engines are. It was my understanding that 488 and then 487 were to undergo their 1472 day inspection this winter. I know that 463 is in front of the roundhouse. but not sure which is in front of the Engine House, who is inside and who is at Antonito. Can someone fill me in and also whether that is correct about 488 and 487?
Jim Reynolds
Unread postby jonathan c45 » Tue Nov 18, 2014 10:36 am
Jim Reynolds wrote:I have lost track of where all the engines are. It was my understanding that 488 and then 487 were to undergo their 1472 day inspection this winter. I know that 463 is in front of the roundhouse. but not sure which is in front of the Engine House, who is inside and who is at Antonito. Can someone fill me in and also whether that is correct about 488 and 487?
487 and 489 and 463 in chama 488 in antonito
jonathan c45
Unread postby Rich Murray » Tue Nov 18, 2014 10:40 am
Only '87 is due for the 1472
Unread postby Larry Gibson » Tue Nov 18, 2014 11:13 am
Smoke from the chimney and activity by #15.
Unread postby Larry Gibson » Tue Nov 18, 2014 11:21 am
15 has been fired up---more smoke:)
Unread postby Sharon Evans » Tue Nov 18, 2014 12:35 pm
15 is moving again maybe to finish the make up of the train.
Unread postby Larry Gibson » Tue Nov 18, 2014 1:17 pm
15 is moving a cut of freight cars out of the way and shuffling cut about.
Unread postby Sharon Evans » Tue Nov 18, 2014 1:48 pm
Not knowing the switching plan, what I am watching makes very little sense.
Unread postby Larry Gibson » Tue Nov 18, 2014 2:11 pm
It appears 15 has spotted a gon at coal dock????? The gon is out of view after last pic and 15 is moving without it.
Unread postby Sharon Evans » Tue Nov 18, 2014 2:21 pm
Don't think its at the coal dock, but they ran around it and are going to shove it back into the yard.
Unread postby Larry Gibson » Tue Nov 18, 2014 2:34 pm
Yep, after considerable time it reappears on the other end of 15.
Unread postby Sharon Evans » Tue Nov 18, 2014 2:53 pm
Seems that every move that has been done this afternoon has taken considerable time to hook up and they move again.
Unread postby Larry Gibson » Tue Nov 18, 2014 4:21 pm
After stepping away got back in time to see 15 still moving a car cut around and then running light down the main and return to the same spot as Monday. Looks like an occasional puff of smoke from the chimney as this morning too. Can't tell if the train is set or not between light and distance.
Unread postby Larry Gibson » Tue Nov 18, 2014 5:00 pm
Steady smoke at sunset. Will we see a steam loco Wednesday????:):) Stay tuned:):)
Unread postby Larry Gibson » Tue Nov 18, 2014 5:15 pm
Late addition: more smoke from Enginehouse. Smoke from another chimney now.
Unread postby Sharon Evans » Wed Nov 19, 2014 6:35 am
Smoke is pouring from the smoke jack on the right at the engine house.
