Hot loco this morning
Unread postby Jack Spencer » Tue May 16, 2023 8:12 am
For the second day in a row we have a hot locomotive warming up behind the house. I saw it undergo pressure tests yesterday. Purely by process of elimination, I would say that it is 488 as 484 is also visible behind the house and is definitely not in steam, 463 is outside the front and 489 does not have its tender. I also saw the backhole load coal into 463's tender so we may see her hot soon as well.
9:14 - 463 is hot too!
Re: Hot loco this morning
Unread postby Allan Kirkpatrick » Tue May 16, 2023 8:28 am
WOW, Hot locos!. 3 locos w/tenders!
Allan Kirkpatrick
Unread postby Jack Spencer » Tue May 16, 2023 8:34 am
Allan Kirkpatrick wrote:WOW, Hot locos!. 3 locos w/tenders!
I am personally curious as to when the repainted coaches from Antonito will return, and how? I guess they'll most likely send either 19 from Antonito to run as far as Cumbres, and an engine from Chama will take over, or have one engine go all the way to Antonito and return with the coaches, as 315 and 168 are far too small for the job and 487 is still being converted.
Unread postby Allan Kirkpatrick » Tue May 16, 2023 9:27 am
What kind of work is being done near the road crossing the tracks towards the rear of the shop?
Allan Kirkpatrick
Unread postby Jonathan Cordova » Tue May 16, 2023 1:44 pm
i wonder which engine is going to antonito to pull the 216 and 215 train
Jonathan Cordova
Unread postby Jack Spencer » Tue May 16, 2023 1:53 pm
Jonathan Cordova wrote:i wonder which engine is going to antonito to pull the 216 and 215 train
Probably the K-27.
Unread postby Tom Smith » Tue May 16, 2023 2:35 pm
Antonito 05.16.23.jpg (107.75 KiB) Viewed 3875 times
I just grabbed this capture from the Antonito CDOT cam. They definitely have a hot loco over there as well, and it appears it may be going out on a test run with some coaches.
Tom D Smith
Mercer, MO
Tom Smith
Unread postby Jonathan Cordova » Tue May 16, 2023 3:16 pm
315 i bet
Jonathan Cordova
Unread postby Jack Spencer » Tue May 16, 2023 3:18 pm
Well, according to Scott Gibbs on the NGDF, it is 168.
Unread postby Jonathan Cordova » Tue May 16, 2023 3:20 pm
168 looks great
Jonathan Cordova
Unread postby Jack Spencer » Tue May 16, 2023 3:22 pm
Jonathan Cordova wrote:168 looks great
Hope they polish the others as well! 484 is still filthy!
